Screwdriver Show - Recommendations on tests
rocksarefun
Louisiana
Hi All,
I am producing a show called "Passing the Knowledge" kind of a comedic how to show where I explore many topics. It's not out quite yet but I wanted to get some thoughts for an upcoming episode:
I'm going to be shooting an episode purely dedicated to #2 Phillip screwdrivers. It's a bit of a comedy in that we all know they will all work, but it will be interesting to compare the perceptions people have. In fact, that's most of the fun in reading garage journal anyways.
Are there are any fun or smart tests that I could do with phillips screwdrivers for practical tests? I'm going to be bringing on a mechanic from a local garage, a home DIYr, and someone who knows nothing about tools.
Some of the brands I'll have:
Matco, Snap-on, Mac, Stahlwille, PB Swiss, Vessel, Gedore, Craftsman, Stanley, Husky, Wera ... thats all i can think of.
Thanks for your help!
Coloshaver
Northern Colorado
It may be beyond your scope, but how about #2 phillips driver bits?
Sort of related to that is how large an angle can you be misaligned before you turn (or spin) out of the screw slot?
Looking forward to your video.
Falcon67
Merkel, TX
Phillips screwdriver = hole punch. Small smores stick. Works good for letting the air out of pool toys. Throw them at a big block of styrofoam like knives and see which ones have the best balance/penetrating power.
R
rocksarefun
Louisiana
@Coloshaver - Thanks I'll keep that in mind, hopefully the mechanic will think about that aspect as well.
@ Falcon67 - Thanks for your very random ideas.
larry_g
oregon
Design a prybar test to see which ones work without bending. Maybe explain the difference between Phillips, JIS, posi drive, and the other 'cross' drive screwheads.
sublimate
Colorado
I have a soft spot for these guys:
was the first "tool" I ever owned as a child. I loved how it kept opening up and you end up with more screwdrivers than you expected - kind of like the nesting Russian dolls.
Maybe you can work one into your test. It would fail horribly as they aren't well made. A well machined one, however, would be a thing of beauty.
Falcon67
Merkel, TX
Seriously - and not sure how you'd set up a test - my main malfunction with phillips #x screwdrivers is that some have more of a tendency than others to climb out of the screw.
Saw
Illinois
Bahco, just bought the ratcheting one this week along with a Wera Komfort Kompact, both really nice screwdrivers. The main reason I bought them was the accolades they received in the old world tools thread. I have a couple Snap-ons, Wiha, Craftsman, Stanley, Picque, and many other 4 ways.
Looking forward to your show, keep us posted.
gotham
Colorado
I believe phillips is designed to climb out of the screw to avoid breaking the screws.
ichabod
minnesota
Give the guy that don't know a screwdriver from his *** one of these to use, might be good for a laugh
justsam
Penngrove, California
Might be fun to ask if there are metric or Whitworth as well as SAE Screwdrivers.
Also don't forget the Reed and Prince which looks like a Phillips, but isn't.
Haveblue
kansas
Demonstrate how using valve lapping compound can give extra bite, and keep the tip from "camming out" I learned this trick from members here..and it does work!
Daves69
Kernersville, N.C.
Use the Enderes Tools test.
I remember getting the Enderes phillips display and was impressed at the tip with no damage after being pressed through 1/4" steel.
rancherbill
Foothills County, Alberta, Canada
You should have these Mastercraft screwdrivers from Canadian Tire.
They are very Good tough screwdrivers with a diamond coating on the tips. It is way better than lapping compound and it is on the driver all the time. The second thing is the shank goes right through and you can hit the end.
They grip like crazy on those screws that have a little oil or dirt on them.
I bought them as a novelty/special purpose set. After using them they are my primary set.
It would be interesting to see their reactions.
http://www.canadiantire.ca/en/pdp/mastercraft-maximum-8-piece-diamond-driver-0573669p.html#.U5JwGXJdWSo
rburke65
Canfield, Ohio
Comedy? We had some young female apprentices at work and they refered to the Phillips and the flat tip drivers as "plus" and "minus"...........hard to believe, but.......
Haveblue
kansas
Those look like great screwdrivers bill!! I'd like to see them tested in the hands of the guests. You gotta love it when an "iffy" tool set turns out to be the one you use the most. This is a good topic! I'm looking forward to the videos rocks!
nicksnothereman
In the Mojave
Hi All,
Strip the hell out of screws and see which one(s) takes it out?:lol: Actually, most will, don't tell anyone though they get kind of protective of their fancy drivers. Nowadays it's more about the handle than the duty...consequently, lots of good screwdriver handles. I'll tell you what, you go get a cardboard bin #P2 from lowe's or home depot for under a buck and I'll personally guarantee it will take the screw out without looking like a t-rex chewed on it.
Easiest way to strip screws (I'd say) is put drywall screws in wood with a drill driver. Yeah you can put drywall screws in wood, you're just not supposed to.:lol:
Stanley is very similar to the kobalt I think. I was just using a kobalt big boy #P3, awesome driver, weighted right, etc. Even I was surprised.:lol:
LS6 Tommy
Northern NJ
One of my favorite tools. Every time I use one of them somebody gives me that confused dog head tilt look...
Back to the OP's request, don't forget to include the JIS (metric) versions.
AFAIK, Stanley & Klein are made in the same factory.
Tommy
R
rocksarefun
Louisiana
Wow! Thanks for all the replies and funny thoughts, good test ideas.
Clearly there are many different brands, and I won't be able to get all of them. But I am getting the majors. Once they all come in I'll get everything in order and shoot it. I had never held a snap on till I ran after the truck to buy one yesterday. I love the handle, its super beefy compared to the european ones I've been getting.
A good point on the JIS, Prince, Reed, Phillips tips. I'll note that in the video because they are technically different tools at that point.
kenfath
Upland, CA
The show needs to include Harbor Freight's Phillips #2.
Actually I have a HF #2 Phillips x 4". It is my 'go-to' #2. Very nicely made, hardened tip fits screws well.
nicksnothereman
In the Mojave
You mean pittsburgh pro obviously. Some of those freebies are hilariously made (the shanks ain't straight in the handle); definitely sort of usable though.
Iron-Iceberg
A-town
I think the slipping off the screw and driving the #2 tip through the side of your finger test, should be at the top of the list. Extra points for not just grazing the side but an actual puncture wound is tops in my book.
