Pro Bit Driver - JIS PH #1, JIS PH #2, 5mm Flat Blade
Precision Bit Driver With Screwdriver Bits Ergonomic machined aluminum body with bearing-mounted rotating cap for precision and control. Magnetic bit drive accepts any standard ¼” hex bit. Internal storage for two bits. Also compatible with Multi-Torque Bit Set. Includes JIS compatible PH#1, JIS...
pedros.com
im interested in this, and curious if anyone has seen one similar/same as this Pedro's?
