*** Screws !
I knew that would get your attention ! Actually, that is on of many names they go by barrel nut, barrel bolt, Chicago screw, post and screw, female screw, binding post or connector bolt.
I am trying to help my son-in-law repair the retractable awning on his travel trailer. The arms are bent severely. Each part of the arm is an aluminum C-channel, with the inner ones folding into the outer ones. The whole thing is assembled with long (~3") rivet with a tube spacer in between. The only way to disassemble this is to grind the head off the rivet and remove it. After we get the channels back straight I will bond (using 3M 5200) a piece of 0.080 5052 to the sides of the channel to reinforce where the kink is.
Unless someone can demonstrate how to place an long rivet back in, I think I need something like a *** screw/binding post, about 1/4" diameter and about 3" long. I can find a few sources online, but they have a very limited selection.
PugetDude
Superstition Mountains, AZ
Sounds like someone forgot to put the awning in before the big windstorm hit...;)
Why not just use a machine screw with a self-locking nut (or drilled and cotter-pinned) At 3" long, it sounds like it is the outer channel?
FYI, a 3" S40 Pipe cap makes a perfect replacement for the cheap pot metal end caps...we used one to get my buddy's 20' wide 5th Wheel awning back in after a microburst, it's lasted longer than the original...
T
EXACTLY ! Like second or third time out camping !
That is clearly the obvious answer but I have 2 concerns.
  • Because this is a pivot point, I am concerned about the (cheap, flimsy, slightly thicker than aluminum foil) C-channel riding on a thread and "wallering out" a large hole.
  • The heads need to be as flat as possible because this channel folds inside of another channel. Truss head screws are good, because the have a very low profile head, plus their oversized head spreads the load.
PugetDude
The awning gets put out maybe a couple of dozen times a year? The sun will probably eat it before the screw wallows out the pivot hole. This isn't a rotating member.
6PTsocket
what about rivet nuts?
That might work. If you actually crimp it, you are using it backward but that might not be a problem. I would still fill up the rest of the space with a spacer, and a dab of blue Loctite to keep the screw in the rivnut.
T
would a shaft the correct length threaded on each end so you can install truss head screws work?
YES !
I don't have a lathe, so the next closest idea is a stainless tube 1/4" OD X 0.049" wall X 0.152" ID that I can tap for a #10 truss head screw.
Got a lathe that can do small work ?
9c1nova
Check with a locksmith shop or door hardware distributor. Some door closers come with Joint connecting bolts (*** bolts ) (thru bolts ) for mounting door closers. They are usually smaller in diameter. You may have to put a washer under the head along with a longer bolt. Hope this helps.:thumbup:
Bruce
joecon
Buy a piece of steel rod cut it to length and thread the ends with a die
and put a nut on ether end. You could even use a T net on one side so
it would be flat. You would have to grind off the tabs or point that stick in.
larry_g
oregon
Well if the *** bolt doesn't work then get a stripper bolt (shoulder bolt). Another would be get a stand-off from an electronics place that is female tapped both ends.
lg
no neat sig line
PugetDude
Oldwizard, made these up on the lathe this afternoon and have them ready to mail. check your PM. Fun little project. :)
