Scroll Saw v.s. Dremel ?
Bulldog13
Cape Coral ,FL
Thought I'd ask the wife for a scroll saw for Xmas- always wanted one for projects in my shop-sign making etc.-- wife was doing some online research and saw a dremel attachment that seemed to perform the same function. Are there any advantages to using the dremel v.s. the scroll saw.I thought the speed control and the base would make for easier precise cuts on the saw.-anyone here a scroll saw pro?
GirchyGirchy
Central Indiana
Which attachment are you talking about, exactly? Hand-held or bench? Either way, it's doubtful any Dremel attachment is going to be as good as a real scroll saw.
James E
Raleigh, NC
Considering how many different blades, bits and attachments I have for my two Dremels, I use them a lot less than you would think.
I have come to the conclusion that the Dremel is only a band aid for use until you can get the appropriate tool for the job.
For the most part, the only thing I regularly use my Dremel for is carving Pinewood Derby cars.
pablo94sc
Memphis
I like my rotary tool as a sander/grinder for tight spaces and small areas on the project where I need to remove a lot of material fast and with relative control/precision. It's a nifty tool, and really good for crafts and odd jobs, but like James E, it mostly sits on the shelf compared to my other stuff.
Bulldog13
Cape Coral ,FL
I have the flex attachment for the Dremel and these new bits were cutting bits. It kind of reminded me of the Roto-Zip tool. They were actually using it to do wood carvings- I think though it would be easy to ruin something without the base to support the piece your working on.
James-W
Southeastern Wisconsin
I have both tools and I seldom use either one. Every tool has a use, and if you have a need to use a specific tool, then it is great to have it. I have used my Dremel tool for things like cutting off small nails on a project I was working on. A cutting wheel works really good for that, but you have to keep the cutting wheel perfectly straight or you will break it every time. In my opinion a Dremel tool is mostly for real small jobs and is not a tool most people would use on a regular basis.
A scroll saw is something I seldom use either, but to a person who creates signs, depending on the signs, a scroll saw may very well be a tool you would use quite a lot. My oldest daughter uses mine to make crafts which she gives away as Christmas presents so most every year she comes over for about a month prior to Christmas and makes stuff to give away. She cuts out little figures and paints them and I must say, they are pretty cute.
She is kind of getting out of it now though, she is working long hours and quite frankly, she doesn't have the "drive" to work all the time and then do this on what little free time she has.
Anyway, my advice is to get the scroll saw, but get a really nice one, don't get a cheap one that you will be sorry for later. If your wife gets it for you as a gift, (I know this will sound rather "tacky" and certainly not "cool" by any means) make sure you give her a "hint" as to which one you want.
kaymccampbell
Upstate New York
A $47 Dremel attachment does not a scroll saw make. Each one has its place. If your intent is to do a half hour's scroll saw work in a day, one time in forever, then get the dremel attachment. If your intent is to do a significant body of work over a long term, then get the scroll saw.
GirchyGirchy
Central Indiana
Hell no! If used for what it is - a high speed rotary tool - it's fantastic. It's all the other stupid **** that tries to make it into something else that's not great.
ZipSnafu
Virginia
I use my Dremel often. I use it on my small projects. I think it is a great accessory to my tool collection.However; it does have its limitations and should be use accordingly.
nh_yota
Seacoast New Hampshire
I think an oscillating tool is way more useful than a Dremel rotary tool. I may only use my Bosch multi-tool a few times a year but man has it saved my **** more than once.
If you do a lot of wood or metalworking then a rotary tool will probably come in handy for trimming small pieces, but for someone like me who does a little of everything an oscillating tool is more practical. Everything I would use a Dremel to do can be done with an oscillating tool or a hand file/rasp. As for the scroll saw vs. Dremel, I think the scroll saw is more useful for woodworking and if I had the space for a bench top scroll saw I would definitely have one.
My order of preference is:
1. Oscillating tool
2. Scroll saw
3. Dremel rotary tool
I should add that both my brother and my father have had Dremel rotary tools for many years and I can count on one hand how many times they have been used.
MoonRise
Want/need a scroll saw?
Get a scroll saw.
Without going into the four-figure price realm (Hegner http://scrollsawreviews.com/?s=Hegner+18"+Variable+Speed), go for the Dewalt DW788. Usually just under $500.
http://scrollsawreviews.com/dewalt
http://lumberjocks.com/reviews/2337
http://www.finewoodworking.com/2005/06/01/scroll-saw-dw788-review
Dremel tools are handy for what they are. I have several. But they are not a scroll saw, even the Dremel Moto-Saw IMHO
https://www.dremel.com/en_US/products/-/show-product/tools/ms20-dremel-moto-saw
James E
Raleigh, NC
I'm not saying a Dremel doesn't have its uses. I'm just saying that it's no substitute for the right tool. If the OP is trying to decide between a scroll saw and a Dremel for some very specific uses, I can't see how a Dremel would be an adequate substitute.
And if he is willing to give up the abilities of the scroll saw because of some perceived added usefulness of the Dremel, I am just warning that a Dremel isn't as versatile as they make it out to be.
The Dremel just doesn't have the torque it needs to do about 75% of the things they imply it can do.
LX-Markham
Markham, Ont.
No, even an 'attachment' will not make a Dremel substitute for a proper scroll saw.
That said, I find the Dremel more indispensable than the scroll saw. I use both often, but I come up with uses for the Dremel that I never would of though of before owning one. If I had to prioritize which one I got first: I would pick the Dremel.
I am just warning that a Dremel isn't as versatile as they make it out to be. The Dremel just doesn't have the torque it needs to do about 75% of the things they imply it can do.
I respectfully disagree. I find it extremely versatile, and the one I have is very torquey.
