Scrubbing new floor?
WisJim
Menomonie, WI
The concrete slab for my new shop was poured last April (2020) and after lots of slowdowns and material problems it is closed in and will get interior paint in a few days. I'm thinking that it wouldn't hurt to really clean the floor before we start moving tools etc into the building. The floor was sealed last spring but I can't find the note where I wrote down what they used--it was a simple spray on sealer of some sort.
My question is, what kind of scrubber/polisher/equipment would work to clean the floor well for an initial cleaning? When I look for rental floor scrubbers I find commercial machines that you might scrub a gymnasium or school corridors or something with, much bigger than I could maneuver (or afford).
And that kind of thing isn't available nearby anyway.
Thanks for your help.
benwah
Lakewood, Colorado
If a mop and bucket is out of the question you could try a 17" swing buffer buffer (Or similar size). Most hardware stores will have something like that for rent.
Matt Johnson
Washington State
When I had a commercial space that had a bunch of concrete covered in drywall dust & taping mud, I first scraped up all the mud clumps from the floor & then tried a wet mop. But I found that the dust was both too thick & seemed to just move around more than pick up.
So I rented a Tennant T1 Floor Scrubber - https://www.tennantco.com/en_us/1/m...ct.t1.walk-behind-micro-scrubber.9004191.html
It's compact, especially when the handle is folded down, so you can transport in most vehicles.
IIRC, I didn't use any cleaner, just straight water.
But if you have some staining, I'm sure you could.
I've used Tennant's T3 model with their cleaners in automotive shops & they work well, but not easy to transport IMO.
I did a quick search for you & it looks like the Sunbelt Rentals in Roseville/Minneapolis rents the plug-in/corded or the battery powered (my preference) -
https://www.sunbeltrentals.com/equipment/detail/1775/0400103/scrubber-micro-w-b-battery/
I wish you well on your project & finally getting to work in your new shop.
Matt
W
WisJim
Menomonie, WI
I may start with a stiff broom or brush and soapy water and wet vac and see if that does enough, then maybe find a rental scrubber. Thanks for the suggestions.
