Sea Container question
twarren
Roseneath, Ontario Canada
I'm looking at purchasing a sea container for storage. Items will be paperwork and some older motorcycles. Just wondering if condensation is an issue and if so, what might be some preventative ideas.
Twarren
The Tool Tyrant
Bonita, Ca. (San Diego)
I have three 20 footers at my shop and a 40 footer at my house and have never had any issue with condensation. FWIW, I'm located in San Diego and I'm not sure if this is an issue in other areas.
Firebird 1
Maryland
I have used them for years for construction job sites. Leaks are generally a problem, but that can be corrected. Cant say I noticed condensation though. Keep in mind, they only part with these when they become about half wore out. Also, around my area they are not cheap. Small ones (not sure if they 20 or 30') usually go for 3-4 grand.
turbowoodworker
Apex NC
It really depends on your local relative humidity. I have one forty footer here in NC and it rains inside sometimes.
I had boxes of books that did not fare too well. So if your papers are important, think twice.
ADSR
Here on the wet coast, I had to spray foam the ceiling on mine. It solved the problem.
gtcs
nm
I work construction and my old employer had several, some had old filesin it. Here in southeastern New Mexico, I only remember condensation once in the last 12 years. But it was in THAT con-ex. If I were string paper goods I would keep them in file cabinets or tarp them.
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
I have two containers and both make use of these.
jfish
Tacoma WA
I had many of them in use at my previous employer. And we used the method HOTFR8 mentioned. One 53' was only for dry file / bankers box storage. Several of the cans we simply ran power to it and plumbed a fan into the back upper wall as well.
kbs2244
I go with the turbine vents.
Air circulation is what is needed.
They give it with no power needed.
pcmeiners
Circulating vents will do little in a humid climate. The materials inside, especially paper will absorb moisture, then when the air temperature drops condensation will happen; he is talking Ontario, not one of our dry states, like New Mexico or California. Best bet is to purchase an insulated container with no damage to the door seals, even with an insulated container moisture is still an issue unless heated .
