Seal concrete before Racedeck?
gsea
I had planned on doing epoxy floors, but then I came across some used Racedeck for a song and figured I'd try it out. I'm concerned about moisture as I live in an area with snowy winters and I do a lot of automotive work so there will inevitably be some spilled fluids at somepoint. I also have a hose bib in the garage and have become accustomed to just hosing off the floor.
Is any of this a problem with Racedeck?
Should I do a cheap sealer before installation?
If I put down a sealer and decide I don't like the Racedeck, does it compromise epoxy installation down the road (would grind anyway)?
Anyone tried the gardening fabric underneath to cut down on the clack-clack noise when walking on Racedeck?
LegacyIndustrial
deerfield, IL
If you will go with epoxy later, use a product like our HD6600MMA. Waterproofing sealer that can easily be ground off for a more high performance product later.
Armorpoxy
Hi, we have a new product called Spray Floor sealer you just spray on with a garden sprayer for about 20 cents per sq foot, that should do the trick. No prep needed for bare concrete.
Thanks!
