seal killer's Garage Remodel
seal killer
Kansas City
All--
Five years ago, I stuck a mill in the garage and began calling the mill area a shop. I built cabinetry around the mill so everything I needed for operations was close to hand. My cabinetry building skills are primitive, but it all worked very well.
Now, I want to put a lathe next to the mill in this two car garage and still have room for my wife's hemi Grand Cherokee, my Crossfire, and bling-bling Sportster. Here is a before picture of the shop area . . .
I had put all that cabinetry together with deck screws. It came apart like an erector set and I saved every bit of lumber. (I am not sure my wife views this in the same positive light as do I.) The mill, all dressed up to go in the driveway, looks kinda lonesome . . .
Now, it is empty enough for me (actually, Mrs. seal killer) to figure out the paint and floor scheme. After an hour or so of deliberation, "we" came up with what I was to discover on this forum was the tried and true scheme; gray on gray with a red stripe. Here's a bit of that process . . .
That mill doesn't want to leave the safety of the garage! But, leave it must for the epoxy floor to be installed. I used Hilman Rollers under the back two corners and one under the front center. Four rollers is bad juju. The base of the mill does not flex. A roller will slid out with the slightest dip and you will be left with a 1400 pound machine on a three legged stool meant for four. Not good. Better it be a three legged stool--a tripod--in the first place. (I have to thank BadDog over on "The Home Machinist!" for this piece of invaluable advice.)
Invaluable friends are EXPENSIVE!!! Look what I had to pay them with!
The garage LOOKS a lot bigger with nothing in it, but I know this is false hope! :)
Now, "all" that's left is the floor. I decided to go with a Tennant epoxy product. Here is the sample I chose . . .
I have been told by very knowledgeable people on the The Home Machinist! that if I ever drop anything on that floor, I will NEVER find it. Fortunately for me, I have never dropped anything in MY ENTIRE LIFE! So, no problem. :)
The floor goes in tomorrow . . . er, in a few hours!
--seal killer
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Looking forward to seeing the finished product. Make sure you take some pics of the actual install if you can.
Falcon67
Merkel, TX
I can tell you from experience on my gray epoxy floor - no specs or fancy counter top looking application, just gray - that dropped stuff runs and hides perfectly well on it's own or becomes immediately invisible, unless it's the size of a coffee cup. ;)
Nice - welcome over to the garage nuthouse.
rickairmedic
louisville ,Ky
The garage is shaping up nicely " although with a mill in it to begin with it looked good to me :D . What lathe are you going with next to the mill .
Rick
larry_g
oregon
Welcome over the GJ seal killer. I hope you do as well here as you do on Chaski. I really enjoy reading your adventures.
lg
no neat sig line
