can you tell me what you used and what prep you did, thats the look that I want. it looks good. my floor is about 10 years old with a brush finish I hope it will look that good.
The sealer is Quickrete wet look sealer that I bought at Lowes for around $120.00 for five gallons. I did about 2/3 of the 30x48 barn so far. I did two coats. There is about a gallon and a half l or so left. So it will be close as to whether I will need to buy another gallon.
I also bought the Quickrete etch/cleaner. I used the etch/cleaner, the cleaner was $20.00 per gallon and did about a third of the barn. I thought it was pricey. So I cleaned the other third with simple green degreaser and muriatic acid dilluted to 24oz per gallon of water. Using the same technique as with the etch/cleaner and I got similar results, except the muriatic acid was only 7.00 per gallon. I also final cleaned the concrete with a pressure washer. Came out very clean although I still had some a few oil spots that did not come out completely. Then I applied the sealer with a sprayer and a roller.
I wanted something cheap that would prevent my concrete from absorbing oil and chemicals.
