Sealer prior to rubber floor
Aegwyn11
I'm getting ready to put rubber flooring down on a concrete slab and am getting all my ducks in a row. The glue I'll be using (Dritac 7700) is a MS polymer adhesive. For this application, its moisture spec when used as an adhesive only is 3 lbs per 1k sq ft per 24 hr. I did a calcium chloride test that gave a result right at that spec, so I figure it would be safest to seal the concrete before putting the adhesive and rubber down.
So here's the question - what concrete sealer should I use that will both block minor moisture from coming up through the concrete AND is compatible with MS polymer adhesives?
Thanks for the help!
A
Aegwyn11
Awesome, that looks ideal. I'll have to call them and make sure it's compatible with MS polymer adhesives. Fingers crossed. Thanks!
A
Aegwyn11
Called them and they were super helpful! This product is perfect for what I need. Thanks again!
b-boy
Buffalo NY
I have rubber flooring in part of my pole barn. I didn't need to use an adhesive. It stays put.
