Yes. Just be mindful that they are not very durable and they will have to be removed first via grinding if you plan on using a sealer or coating at a later date. Here is an example of such a product.I wanted to seal ASAP as I want to use garage and don't want to get floor dirty waiting 28 days. I have been told that there are curing sealers that can be used on newly poured. Any body familar with these?
In my research, Ghostshield 8510 seems to be a great sealer to help prevent oil stains. Sounds like it won't change the appearance and requires just a good cleaning for prep.We would suggest 28 days before sealing. We do not offer color sealers. We do have the Ghostshield products
CorrectIn my research, Ghostshield 8510 seems to be a great sealer to help prevent oil stains. Sounds like it won't change the appearance and requires just a good cleaning for prep.
Personally I avoid mixing sealersInteresting. I just had a broom finish driveway installed, contractor said he used Diamond Clear to seal, and recommends a recoat in the spring. Would this Ghostshield be a better solution in the spring and be compatible? I have a couple of 2004-2005 vehicles that have minor oil leaks that I don't think I can get fixed before starting to park on the driveway in a couple of weeks.
