Rocky98Formula
My parents have a deck with a garage space under it at the back of their house. This deck was built over 25 years ago and uses a couple inches of concrete as the deck surface. The way the deck was built, water has always made it's way down into the wood frame that supports the deck. So much so that at one point 15 years ago the entire supporting wood frame structure had to be replaced because it had completely rotted (deck surface supported on jacks and walls rebuilt).
Eventually we managed to vinyl wrap the concrete surface and add flashing and gobs of sealant to prevent water from making its way down into the frame. It held up well for over 10 years like that. However, my mom recently replaced the deck railing with new aluminum rails and the installers ended up using screws through the vinyl into the concrete to secure it as seen in pictures. Needless to say, water has started making its way through the deck again. Any suggestions on the best way to seal this mess? Ultimately we need to seal between the aluminum base pads and the vinyl as well as around the screws? Is there a type of sealant that would work better than others? The house is in Vancouver where it rains and rains but usually no snow.
