Sealing limestone steps
rmanrman
I have three steps concrete block with 2-1/2 limestone slab stair treads leads to back man door.
Is there a product that will seal the limestone but not get slippery when wet ?
I ‘m asking because when the water seeps through the limestone steps during the winter the concrete blocks start cracking and the limestone cracks where the hand rail drilled holes are. The posts are well sealed with epoxy.
I’m in an area where the temperature does fall to 10 degrees F.
CamMark
Palmetto State
You may find more feedback and expertise in the flooring section.
Similar to what I used, Ghostshield has a penetrating sealer usually used for concrete, but does mention natural stone in the application list. siloxa-tek 8500. It works really well and because it's "soaking in" rather than creating a film on the surface the texture doesn't change and become slick.
