Sealing old concrete floor
Tracs
Manitoba, Canada
When I had my slab poured 4 years ago I told the contractor I wanted to seal the floor. He had me pick up Kure-N-Seal. It went on like Milk and dried away unnoticeable. I thought that it would be done after that and we would move on. All it did was help it cure I guess.
The surface has been very porous. Since then I have spilt numerous oils, chemicals, ect. on it.
I vacuumed and mopped it today to get the winter grime off it and it got me thinking again.
The Kure-N-Seal that was applied will soften up and wipe away when using brake cleaner.
My Dad's garage floor has a coating that is like a clear shellac. It is slightly glossy and oil will wipe away without soaking in. I think he said it is the same stuff they put on exposed aggregate driveways. His is not slippery.
Is it too late to put a shellac type coating on it now? What would I use if it was possible? I don't care about seeing the stains or anything like that through it.
T
Tracs
Manitoba, Canada
Added pictures.
lakeroadster
Central Colorado
For just a regular workshop floor I wouldn't do anything for prep but what you have done already.
I use Eagle Natural Seal on the concrete slab in my barn.
It's available from Home Depot, $78.92 for a 5 gallon pail. Shipped to your door for free.
It doesn't change the look of the concrete, just seals it.
Water beads up nicely.
When I was installing my 2 post Rotary Lift about a quart of fluid (Auto Trans Fluid) leaked out onto the floor, I cleaned it up, you can't tell it ever happened. That proved it's a good sealer to me.
Check out my build thread below.
