goalieman24
- Joined
- May 10, 2017
- Messages
- 5
New house, new garage project. It was once detached but has been connected, however it still has the makings of a primitive detached structure. Good bones, great space... just needs to be classed up.
Not sure if this type of "technique" has a technical name but it's basically wood siding with little slats on the inside covering the space between boards. The first order of business will be to seal up the inside where the slats aren't covering the gaps. I suppose I could just repair the problem areas with new slats but there are enough (as well as a few other imperfections in the boards) that it seems like it would be pretty laborious patch work.
The main goal is to provide a seal against moisture as well as insects/critters. Ultimately the inside walls will be "finished" to cover up the studs... probably just with plywood. Not sure if I will insulate it.... however a spray foam is seeming (to me anyway) to be one of the most efficient ways to handle this.
See pictures below of interior and exterior. Some of the gaps are as pictured where the slat is either warped or has just become unattached... some are where the slat just isn't the right size and there are gaps at the top/bottom.
