rallenc
I was installing a stainless steel line through my basement wall for a hose bib. Thought I would get fancy and use stainless steel threaded pipe through the wall and for an 18 inch rise to the faucet. Used stainless fittings also.
On each joint I used the yellow "teflon" tape. Finish up and every stainless joint has a drop-drop leak. I noticed that the threads both male and female were very sharp and in a number of cases the "teflon" tape didn't seem to want to "grab" but had a tendency to rotate with the fitting as it was being installed.
In hindsight I did some research and it was recommended that Loctite, I think 567, would be better than the "teflon" tape.
Any thoughts on joining stainless threaded pipe?
Thanks for your wisdom.
