Sears Craftsman Bench Grinder - any worth?
freebo86
Figured I could use a bench grinder in the garage.. sourced this on marketplace. When I got there I realized this things bigger than I expected. My garage space is limited.. 🤦‍♂
Figured since I went there I picked it up anyways, $20.
1/2HP, Sears Craftsman, I pulled one of the wheels off its 7”, arbor size 5/8s. The wheel I pulled off seems to be for aluminum, the other wheel I think says steel on it. The light even works. when I run it and turn it off it spins forever until it stops. Looking online these things are listed as 6” grinders so I’m a bit confused now why there is a 7” wheel and it looks to be original.
Should it actually be running 6” wheels? I was thinking of cleaning, and repainting the larger parts (mini-resto). Need to replace the cord on it as it’s frayed. But would like to know if it’s worth it before I dive in.
Thanks!
RoninB4
Under My House
-If this is the wheel you interpreted as "for aluminum" I can assure you that it is NOT for grinding aluminum. Aluminum oxide wheels are very common but used for steel and ferrous materials only. If you want to know why just ask, I'll tell you and you'll be sorry you asked.
Attempting to grind aluminum with this wheel will quickly clog the wheel with material and render it almost useless. If enough material clogs the wheel there's even a chance the wheel will explode when the aluminum expands with heat, very dangerous when that happens. There are other abrasive wheels (silicon carbide) for non-ferrous materials but I wouldn't suggest the average consumer use these as they're very soft and aimed at industrial applications. How to tell some novice has attempted to grind aluminum? The wheel begins to look like this.
The only solution for this condition is to dress the wheel until ALL the aluminum comes off. Before anybody replies that they've ground aluminum in a bench grinder with an Al2O3 wheel please spare yourself the embarrassment of revealing that you're an idiot that should not be allowed around a bench grinder without adult supervision. If you must somehow abrade a non-ferrous material (aluminum, brass, some SS, etc.) use a flap wheel, sanding belt, or some other type of abrasive. A clogged bench grinder wheel immediately confirms that there's an idiot in the shop/garage.
Lassen Forge
Um, it's not FOR grinding aluminum, the abrasive is Aluminum Oxide.
Silicon Carbide is used for non ferrous, but are a whole different animal, and can get expensive even WHEN used correctly.... I have a set of SiC wheels for my grinder, but don't mount them unless I'm working with bronze or aluminum or some other NF metal.
fatfillup
Finksburg, Md
$20 for an 1/2 hp Cman block grinder.
That's approaching suckage status, many would say you do ****😂
I sell those from $50 to $80 depending on condition and buy every one I can.
Bought an absolutely filthy one last week at an auction for $5. Needs wheels but runs fine
Enjoy
seber
Deep East Tx.
If the wheel fits and the speed does not exceed the RPM listed on the wheel, you are fine. As Ronin stated, NEVER grind aluminum on a bench grinder. And it does not matter what type of abrasive the wheel is made from. Just don't do it.
