sears motor help
wazzabie
The data plate on the motor is
model C-140-3013
5KCR48SR59W
RPM 3450
V 230
A 13.1
Code 839M
PC B1037
40C AMB CL
It is on s sears 5hp air compressor. The plug on the compressor is for a nema 6-20.
Do i then need a 20 amp breaker?
I currently have a 30 amp breaker 10 gauge wire 240v hooked up to a 200amp service panel running to the location where I would like to have the air compressor. Can I install a nema 6-20 oulet on this run?
Thats not a true 5HP motor. Amps are too low.
Its more like a 2 or 3HP motor.
Nema 6-20p will be fine with #12 wire. Breaker needs to be 20a.
Motor circuit wiring is sized @ 125% of NEC FLC.
Breaker can be max 250% of NEC FLC.
EDIT: I really shouldnt type up technical comments when Im half awake. If u use a 6-20P and r, then the breaker needs to be 20a.
W
wazzabie
Is it ok if in install a Nema 6-20 outlet on a 30amp breaker?
md21722
Mt Juliet, TN
Yeah, I just realized we were talking breakers vs outlets so I deleted my message before even seeing your response :)
pattenp
Virginia - USA
Nema 6-20p will be fine with #12 wire. Breaker can be 20a or 30a.
That's okay for a hardwired motor circuit, but not a circuit with an outlet.
Read NEC 430.42(C).
Gttrucker
Wyleisdeisels is correct. That is not a true 5hp. If I recall correctly 1 HP equals about 750 watts, so 5 HP is 3750 watts. At 230 that's 16amps.
So your fine with 12 gauge line and 20 amp connectors even if it was a true 5hp. I always wonder how they come up with HP ratings on motors. Air compressors are always over rating their power to sell their stuff.
A note on the cord. I see a similar problem with extension cords. They often have more resistance than the rated gauge should have, so if your planning to buy a coed and cut the end off (as opposed to just buying cable) then I'd get a 10 gauge cord 'cuz I don't trust their numbers.
Gttrucker
If this is a stationary compressor you could just skip the plugs and cable and hard wire it direct with 12/3 armored cable. It's fairly cheap and handy to have on hand for running extra outlets etc.
Gttrucker
pattenp is right. A true 5hp should have a 30amp/10ga line ... hmmm but this is not really a 5hp motor it's a 13amp motor so 12/3 should be fine.
W
wazzabie
I currently have a 30amp/19 gauge line going to the location. If I put the 20gauge outlet on the line and only used it to connect the air compressor would that be ok?
Thanks for the help
pattenp
Virginia - USA
Thanks for the help
If you have #10 wire you can use a 20 amp breaker and a 20 amp outlet. It's going to be tough connecting #10 to a 20A outlet and getting it all back into a standard single box if that's what you have. You should not use a 30A breaker.
Thanks for the help
19 gauge wire? :wtf: Thats really small.
I hope u meant 10 gauge...
