Securing a Cord Through a Panel
PZ 1
I am running an electric cord through a metal panel. I would like to use what I would call a grommet, but is called a "strain relief bushing" or "snap in cord connector". It is a two piece plastic clamp that goes on the cord and then snaps into a panel. I cannot find one large enough, the cord is .570. There is no access to the back side of the panel to put a fastener on. If nothing else, I could use a rubber grommet, but would like the cord secured so it cannot pull out.
Any suggestions on something that will work?
darkzero
SoCal
I've known them to be called strain reliefs. Normally for larger sizes, rather than the pinch & snap in type, they usually have a collet design. Not sure what to call it. Basically the body is secured with a nut on the backside h the cord is secured by a tapered nut (inside taper) from the front. They come in plastic & aluminum. I've purchased the aluminum ones from Mcmaster.
You mentioned no access from behind to use a fastener but do you have access at all? For low strain relief cases I have gotten by with using a zip tie on the cord so it can't pull out of the hole or simply tie a knot in the cord.
P
PZ 1
It is going into a 3 inch square tube, 46 inches from the end.
P
PZ 1
Thank you for the replies. After a lot of on-line time, I have found a correct size strain relief bushing.
Git
S Cal
How about a Cable Gland?
WoodsTruck
Drill and tap a hole for an eye bolt, anchor cord to the eye bolt with minimal tension going through the grommet?
Miss the Pontiacs
Saskatchewan Canada
How about just wrapping with layers of electrical tape and taper it as you go. In addition you could drill a couple of holes close together put a tywrap through the holes and synch it up to hold cable in place.
csp
Franktown, CO
Care to share where you found it?
Also quoted for those who keep thinking you need more suggestions.
P
PZ 1
Thanks - and I'll add again that there is no access to the back side. I got the strain relief from eBay! That was the first place I looked - but it's a long story.
