Sediment buster
killahog
Morrow County Ohio
I was thinking about buying one of these, and then thought it shouldn’t cost $40.00 to make one. I was thinking about using 3/4 copper but I am stumped on the valve stem .
Any ideas ?
PCustoms
VT
What the heck is it?
You can buy valve stems pretty much anywhere, I know tractor supply has them probably Walmart and I just ordered another four pack off Amazon last week
rjacobs
Dallas, TX
I bought one. Easy to use. You will probably jack around for a while trying to piece something together to work and save what, 10 bucks...
Its not an expensive piece IMO.
If it was 100 bucks, sure probably time to make something, but for 40 bucks...meh...
PCustoms
VT
It wasn't the last time I drained the heater, 3 years ago.
Then why worry?
I had one that was so full I couldn't get the bottom element out. A blast of air may have been useful there, I ended up with a poker and a small vacuum hose to buy enough time to plan a replacement heater
CraigStu
Blacksburg, Va
Go to an auto parts store. You can buy the type all rubber valve pictured. But maybe a better option would be a metal valve. They have a shoulder on the wide base, then a rubber washer, then whatever it is inserted through, another rubber washer, a metal washer and finally a metal nut. Or a single rubber washer that gets squished enough to not need a second one.
They end up being more stable w/ very little tendency to lean over if you can't get the air chuck on exactly straight.
MerlinsBeard
MD
Are you trying to drain a clogged outlet without incoming water pressure to the tank? I've had tanks that won't drain with the water off, but will drain with incoming pressure on the tank. If you can't drain with incoming water pressure, then you got an issue.
I know it should be easy to remember, but turn off the power first. To do anything to the water heater, I first confirm that the power is off with a non-contact voltage probe.
txvwnut
Bedford, Texas
I mean a quick hit with a blow gun on the old air hose should do about the same as that forty buck apparatus, or a coat hanger straightened out and shoved in the opening.
