No. The Studor unit is no better than the pro vent. And if the pro vent is not legal by you why would the studor vent be? Same internals, a rubber disk flap, the only difference between the Studor brand vent and the pro vent is $19, I have used both in a situation where the vent repair would cost thousands and truth fully I would in my own home not use them if I could do a proper out the roof vent.
Both leak, both last 5 to 8 years. If in doubt change it out. They are band aid units and any code that would allow them as a long term product is a poor quality code. You should never put them in a wall, you'll wonder why your house smells like *** and why you have a head ache and muscle pain.
In certain places you get a real nice mould problem from them discharging the water vapors when they leak.
The provents diaphragms wrinkle from drying out and then they are done. Same with these Studors.
If you would use these in your home in a case where you could easily put in an atmospheric vent up and out the roof I would call you a lazy slob. And 9 times out of 10 a guy who uses them cause they're cheap will be too cheap to swap them out in 5 years when they stink his home up.
So the guy getting methane gassed continuously, that just makes him even more incapacitated.
Just swap them out every 5 years, they're temporary until you remodel your home and can do a proper vent.
