JohnMcD348
OK, I'd like some advice from you folks who live and die by your workbench in the garage. I have a work/storage area on the side of my garage that I want to build a general purpose workbench into.
Here's a shot. Please pardon the mess, we're still moving in.
It measures approx 103"x68". The outlets measure 42" from the floor. I am thinking of building a bench that measures between 60 or 72" by 36". I have a set of plans I got off HammerZone and used it to build a reloading bench and it's worked well for me. I can modify it to work for what I want.
Some other thoughts I have about the bench would be for the underframe to be built so that the table top is about 6-12" over the legs. Also I would either build pull out drawers on both sides or perhaps build one side as a small lockable cabinet with the other side lockable drawers.
What I want from you guys is input on the general design and layout. Do you think 3 feet is too wide? Too Narrow? When building should I go with 4x4 for corner posts or would reinforced 2x4's be fine? I want to be able to install at times things like a vice, bench grinder, electronic equipment, pretty much anything at any time. I'm a pretty much do anything , any time kinda guy. Part carpenter, electrician, mechanic, gardener, whatever else is called for at the moment.
Whatever your thoughts are, I'd like to hear them. This is the first time in my life I've actually got the opportunity to have a real work bench instead of having to use the kitchen table or throwing a board over a set of saw horses when I needed/wanted to do something.
Help a guy get a good start on his garage.
Thanks
Thanks
