I'm insulating interior walls for a renovation project in NYC. The building is 3-story with steam radiator heat. The building is attached to adjacent buildings on both sides, so only the front and back walls are being insulated. There is minimal framing up on the front and back walls currently, so installation should be straightforward. The insulation is being installed on the 2nd floor.
Front and back wall measure about 20' wide by 10' tall. Back out the windows and I'm at ~290 sq ft.
Foam board seems like the easiest way to go.
There is space b/w the noggin (filler) brick and the top and bottom plates. This was done to keep the steam risers behind the drywall. My plan is to install the foam in that space.
Seems like the best bang for the buck is this RMAX foam board. R-13.1 for $30 a board.
RMAX Pro Select R-Matte Plus-3, 2 in. x 4 ft. x 8 ft. R-13.1 Foam Insulation Board
Rmax foam board link
I have a foam gun to fill in the voids.
Here's the space I'm insulating.
Thoughts? Advice?
Thanks
Thoughts? Advice?
Thanks
