Seldom used tools that you're glad to have when you need them
cgrutt
So needed to use a screw extractor set that hardly ever gets used yesterday and boy I'm glad I had it. I'm restoring a vintage drill press and a dog point screw on the upper bearing collar for table lift assembly was sheared off. After fussing with it for about an hour I filed off what little remained of it, center punched and drilled a small hole in it and easily removed it with the screw extractor. I think I only used the extractor one other time. It worked great!
So what tools do you guys hardly use but are glad you have them when needed?
Wes J
Peoria, IL
8 point sockets. Everyone should have them. Every once in a while I run across a square head adjusting screw or drain plug that has already been mangled by some ape with an adjustable wrench. An 8 point socket makes it a non issue.
C
cgrutt
Ha! I didn't even realize that's what eight-point sockets are for, LOL... I think I have a few and never use them. There are some square headed bolts on this drill press that I'm working on, I'll see if they fit. Thanks!
Jim C.
Just wondering what you were using to turn those square head bolts if you weren't using 8 point sockets?
bwringer
Indianapolis
20 ton hydraulic press.
I don't use it all that often, but it's paid for itself soooooooo many times over.
thegroundpounder99
Balm Fl
Yes 8 point sockets are great to have, I use them a lot and not many people know what they're actually for. My seldom used tools are Fuse Buddy kit for chasing shorts and a bolt out set. I got both the Irwin and the Craftsman (old set) and they work great. Craftsman ones are great for tight spots.
G_P
Central CT
8 point sockets are definitely handy. Sometimes a square fastener or drain plug is in a location that makes using an adjustable wrench difficult or impossible.
dutchgray
Dorset. England.
I'm going to say Crowsfeet. I have only ever used them a few times but they have got me out of trouble those few times.
Also 48" pipe wrench, if that won't undo something it gets cut out.
Finky198
North East
12lb slide hammer... Bought it a few year back, doesn't see much light but each time I'd be screwed without it.
So far I have to agree with All of the above. I used and own them all lol.
Dave455
Sussex, England
Universal Whitworth sockets!
I need to use these very rarely, but when I do, usually for removing some part from a machine without stripping the whole thing, they are invaluable!
Duker
Livingston, TX
Not sure it's a "tool" but a drain snake..... Between my wife and two daughters and all their associated products it has saved the day a few times.
bobcatdan
Kaukauna,WI
85% of my tools fall into this category.
I would agree, not everyday I use a ball joint press, spindle rethreader, but setter, oil pressure gauge, timing light, flaring tools, 2" wrench, batter cable crimper, vavle spring compressor, Dana 60 axle nut socket, O2 sensor socket, 12 ton puller, hammer drill, Deere engine baring tools and 500 more tools, but when I needs, glad I have it.
WWShop
MN
I would have to say my dewalt trigger clamps. We had a cabinet door crack a few days ago and I was able to glue and clamp it overnight.
Finky198
North East
Agreed ^^^ up 2
We have a few friends that hang out at the shop and are constantly asking what's that for or how often do you use it. Lol but if it's profitable than thats what I care about.
BFHtime
Kool tools braided line tool. Great for custom lines. Not cheap but if I use it once the time saved is about worth the cost of the tool.
I agree with magnetic pick up tool on a wire.
PelicanPines
1/4 inch drive 9/16th socket... Had to remove the 3 point hitch side plates from my tractor today... without that socket... I would have had to remove the rear wheels.
I literally have owned the socket for 30+ years and have used it twice. Once to put this 3 point hitch on... and today... taking it off.
Fedwrench
Valley of the sun
I have a couple brake pressure testers from Waekon that I've only used a handful of times over the last 15 years but, when I needed to diagnose a weird brake concern, they did the trick.:thumbup:
crewchief888
NW indiana
i've said this many times,
i use 5% of my tools 95% of the time,
the other 5% of the time i need 95% of my tools....
:beer:
fastbike02
Walnut Grove MS
Amen I don't understand how a person can loose so much hair and not be bald
L.Cheapo
I tell my wife this on a daily basis.
When I was a teenager, I had never seen an 8 point socket. Guess what? A 1/2" extension turned backwards with an adjustable wrench on the square end can remove the drain plug of a lawnmower! :bounce:
12 point sockets? :dunno:
Actually not the correct tool. A square fastener has 90* corners. A 12 point socket is two hexagons, so the angles are 120*. Will it work? Usually. But not really the "correct" tool.
To stay on topic, my Snap On CJ2002 puller set. I've used it half a dozen times in the 2 years I've owned it, and its more than paid for itself at this point.
