Selecting a chimney size for a woodstove build
MatBirch
Filer, Idaho
I am building a woodstove for my pole barn shop. It's built from 1/8" thick 12" pipe, around 18" long. There is a smoke box on top that is 9x10x12, which is where the flue will will exit.
How do I determine what size chimney I should use? I'm guessing 6" as it seems to be the most common, but I also find 5"...
Thanks!
Jackfre
N CA
That is about the size of the wood fired saunas I used to build. You are going to be burning small stuff and 5" has plenty of capacity. How tall a stack?
