Self Leveling Concrete
nichboy
Oklahoma
I have a low spot (3'x6') in front of my fireplace, has anyone used a self leveling concrete product they would recommend. I have carpet there now so
i would need to put the tack strip back down and relay the carpet. Any installation tips would be appreciated. Thanks
6768rogues
Western NY
Self leveling compounds are available at the big box home stores. In my experience they are all about the same. They work well.
James E
Raleigh, NC
In my limited experience, some self leveling compounds are not so self leveling. Some need help with a screed. Other than that, they are mostly very simple to use.
Is the low spot on a slab or subfloor?
hdshinn
Skagit County, WA
Most that I've used specify a max depth of fill so depending, you might need two applications. Mix according to directions and they flow out pretty level. But has been noted, a good straight screed is still needed to feather the edges of the puddle. Surface tension tends to create a bead around the perimeter.
Make sure the slab is totally clean.
Do you need a bonding agent or any special prep ?
(I wish the tile guy had used some in my sons lower level bathroom. Had to shim the toilet and put in a fair amount of caulk.)
James E
Raleigh, NC
The ones I have used on concrete recommended a good clean of the underlying concrete and a bonding agent.
hoho98925
East of Seattle
Most construction supply companies sell commercial products for this. I have used Ardex products on large scale jobs, products work great.
