Self priming paint vs primer and paint
6PTsocket
I have an old CM hose cart that is all metal and except for some rust was in good shape. Metel carts can be expensive and the plastic ones don't last I just got the rust off the sheet metal and I am ready to paint. It looks like Rustoleum brushed nickle aerosol is about the right color. I have always used separate primer and paint but I see they offer the one step combo, too. Does anyone have any experience or basis for comparison? Paint technology keeps improving. Are we there yet? I would not go single step for convenience if I give up durability or rust resistance. Only hard proof or experience, please, not " I wouldn't trust it" This has been around a while in latex house paint but now I see it is in the alkyd aerosols as well. Thanks.
Dsel74
I don’t know if either primer & paint or the two in one can go directly on metal without an etch primer.
When I tried skipping the etch primer on my drill press it chipped/flaked off.
I don’t really have an answer to your question but maybe have expanded the question.
6PTsocket
I have used phosphoric acid rust remover before priming and that leaves the surface etched. I think a media blasted surface is ready for primer, too. In either case, a good cleaning with something like Prepsall shold be the last step
gofastwclass
KC Area
The only rattle bomb paint I've used on metal that seemed to have any longevity was Rust-Oleum. It seems to be more like single stage automotive paint in a can by how it covers and dries. A friend told me about on their epoxy paint that doesn't require primer several years ago and I'm hooked. Now I use it on all my paint tasks that are too small for mixed paint. I found it holds up extremely well under the hood and for chassis components.
I made some control arms for one of my custom cars and they are holding up great. I didn't prime the metal at all, I just cleaned the surfaces before painting two coats with a dry between them. When I pressure wash them off they still look almost new after three plus summers of driving.
I haven't used any in a place exposed to direct sunlight that I can remember so I can't comment on that application.
fasteddie
I would still use a primer. Either self etch or rusty metal primer if you still have some surface rust. I always thought those "paint and primer in one" paints were a scam. I've never seen the Rusto epoxy DTM, is it a two part mix in the can type thing?
chaosracing
Kutztown, Pa
I still use primer when painting on bare surfaces no matter what the material is. Pros still do it that way, and I do like old school ways so I will always use primer.
For the metal, get a self etching primer (they sell in rattle cans) and prime with that, then paint over it.
RogueFab
Oregon
I have had great luck with rustoleum applied right on metal ONLY when it (the metal) is prepped with laquer thinner.
