Jmatlock88
- Joined
- Jul 28, 2012
- Messages
- 164
- Location
- Tulsa, OK
- Price
- listed
Sell or trade for the items below...
1. Honeycomb core knife with 5.5” blade, 6.5” blade, and 8.5” blade. $10
2. US made Inspection mirror $5
3. Vintage mini SK Tool box $15
4. #30 standard hole finder (has a dollop of JB weld for unknown purpose)
5. #30 standard hole finder (has been ground for additional clearance)
6. #21 standard hole finder (has been ground for additional clearance)
7. NOS Craftsman (USA ) Flat Cold Chisel for air hammer $8
8. Bluepoint Safety Wire Twister/Cutter, Model WT11B, $130 new, $65
9. Rivet Set, Curved, 1” X 0.5”square Foot, L=~1.75 $8
10. USA 12” Scale, paint is a little worn but useable.
11. Wrench style Hi-Lok Collar Removal Tool for size -5 and -6, $50
12. Snap-On ¼” Hi-Lok Ratchet GM70SHL $45
13. HLC1-5 Hi-Lok Collar Removal Socket for size -5 $15
14. Allen USA Hi-Lok Anti-Rotation wrenches $15
15. Extended Footpiece Microstop Cage ZT284012 production rated, .001 increment, $175 new, $85.
16. Blue-Point Hex Socket Power Extractor BET7, missing ¼ and 5/16, $20
17. Reamer Grab Bag, 50+ Piece Set of various reamers, end mills, counterbores, and spiral cutters $150
Don’t like the price? Make an offer or Let’s trade! Below are (mostly aircraft) specific tools I am looking for.
Items considered for trade...
E-Z Change Spring
Air Swivel Regulator
1" Dia. Flush Set **
3/32" Cupped Set 3.5"
1/8" Cupped Set 3.5" **
3/16" Cupped Set 3.5" (only for fabricating spar)
Double Offset Cupped Rivet Set
#8 Countersink - #8 Screw
Snips Left & Straight **
Snips Right & Straight **
#40 Drill Bits (for 3/32" rivets) **
#30 Drill Bits (for 1/8" rivets) **
#19 Drill Bit
#12 Drill Bit
12" #40 Drill Bit
12" #30 Drill Bit
Deburr Tool **
4 Cleco Clamps -1/2" Jaws
4 Cleco Clamps -1" Jaws
Pop Rivet Tool **
Hand Squeezer / 3" Yoke
Flat Set 3/8" x 1/8"
3/32" Rivet Dimple Die **
1/8" Rivet Dimple Die
#8 ScrewDimple Die
3M Cut & Polishing Wheel 6"
325 Cleco Fastners - 3/32" ** (** 30 required)
175 Cleco Fastners - 1/8" ** (** 10 required)
Deburring Set - Large Holes
Edge Deburring Bit
Fluting Pliers
File Card / Brush
#6 Countersink - #6 Screw
Drill Stop Set of 4
Threaded Drill Set 6 pc.
Back Rivet Set **
Dimple Die Organizer
Removable Rivet Tape
Tape Dispenser
Cleveland Edge Formers
Pneumatic Cleco Tool
Fresh Air Mask
3M Deburr Parts
Lightweight Airhose
Book - Aircraft Structural Technician
TUNGSTEN Bucking Bar (Substitute)
3/16" Cleco
Cobalt Jobber Drill 1/4"
Cobalt Jobber Drill #28
"Pop Rivet" Dimpler 3/32" Close Quarters Die Set
Dimple Die Set for #6 Screw
Dimple Die Set for #10 Screw
1/8" Drive Pin Punch
3/32" Drive Pin Punch
Offset Hand Seamer
Rivet Gauge
#30 Straight Flute Reamer
#40 Straight Flute Reamer
#4 Flat Sqeeze die 1/4"x3/8"
#8 Flat Sqeeze die 1/2"x3/8"
Tight Fit Dimpling Fixture (3/
3" Hex Deburring Extension + 100 degree deburr bit
DRDT-2 bench w/ Carpet
5/32" Clecos
Deluxe Airhose and Manifold Block Kit
Beehive spring
Washer Wrench Set
Torque Seal
chip vacuum
other?
E-Z Change Spring
#19 Drill Bit
#12 Drill Bit
12" #40 Drill Bit
12" #30 Drill Bit
Deburr Tool **
Pop Rivet Tool **
#8 ScrewDimple Die
Edge Deburring Bit
Fluting Pliers
File Card / Brush
Drill Stop Set of 4
Back Rivet Set **
Tape Dispenser
Fresh Air Mask
3M Deburr Parts
Lightweight Airhose
3/16" Cleco
Offset Hand Seamer
Rivet Gauge
5/32" Clecos
Beehive spring
Washer Wrench Set
Torque Seal
chip vacuum
other?
