oldpops
Hello all! I have a quick question: We have a PRV valve in the front of our house that is showing signs of needing to be replaced (occasional water hammer, fluctuating water pressure). I know the problem can be further up the chain so to speak (the PEX manifold etc.) but since the PRV valve is 22 years old (never been replaced), I thought it best to start there. I should also say that my father-in-law literally lives around the corner in the same model in the same housing tract, and had identical symptoms. The PRV on his house was just as old and when they replaced it, all his symptoms went away.
Anyway, we have a WATTS Model N45B PRV valve, which I understand has been replaced by the model LFN45b (for no lead). My problem is that try as I might, I cannot get either union nut to budge. I've tried everything but heat. When I really start to 'bear-down' on the pipe wrench, the water pipe coming into the house starts to twist. I should also mention that the house has been painted a few times and the first painter painted over the PRV valve completely. Of course the subsequent painters had to paint over the old color.
Because of the paint jobs, I can't even tell if the union nuts are on the PRV, or if they are on the pipes (the one coming from the ground, or the one going into the house), so I'm not even sure which way I should be trying to turn the nuts. I try to get the union nuts to budge one way, and then the other - but nothing. It's like they are welded! I'm not a plumber, and I wish I could call one but my wife and I are seniors on a pretty fixed income so calling in help is not do-able.
Once I get the valve off I'll probably have to replace the valve, although they do sell a rebuild kit. The problem with the rebuild kit is that they don't come with a replacement spring, and WATTS won't tell me where to get one. (anyone know where to get one?). in any event, if there are some knowledgeable people here who have faced this problem and/or folks here who could offer advice, suggestions, or other help, I certainly would appreciate it! Thanks in advance!!!
