I have a two units each 2 bulb sensor light one over my garage that works great when it works. And another at the rear of the house.
They have been up a few years and a few times a year the one over the garage gets wonky. The rear unit has been rock solid but perhaps it gets triggered less often. I actually purchased 2 newer units to replace these but as luck would have it the power went out and when it came back the unit came back to life. So I put the new fixtures on the shelf in the garage and their they sit.
The only reason I know the power went out is that the cable box say turn on and that only happens after a power failure.
Power outages has fixed / reset them before. I’ve tried cycling the switch or breaker to simulate a power outage to trick them into resetting but it Never worked. Any ideas other than replace them.
These are pretty high up and I’d need to call someone in to replace them.
Thanks
Thanks
