72Anthony
Does it make sense to install a separate disconnect before the main panel for new construction?
In Houston, it is common for the meter box to be installed on an exterior wall of the garage and have the main panel installed on the interior side of the same wall.
In the current house, if I am adding a circuit to the main panel, I can flip the main breaker, but the main lugs are still hot and exposed, especially if routing wire from above.
I am building a new house that will also have a standby generator with automatic transfer switch.
My thinking is that with the separate disconnect, I can more safely isolate the power company's feed when I need to work on the main panel.
If I add the disconnect, does the main panel still allow the neutral and ground wires to be tied together or is it treated like a sub panel, where the neutral and ground are tied together at the disconnect?
Thanks,
Anthony
Thanks,
Anthony
