projectPONY
I need to replace this elbow with a 45º. How would I go about separating it so I don't cut it or destroy it?
TIA
Sent from my SPH-L710 using Tapatalk 2
TIA
Heat it until the solder melts, pull apart. If you plan to reuse part of it, you will need to clean the bejesus out of it.
If we're talking about copper fittings, heat it, pull it apart, then heat/wipe with wet rag until only a solder film remains.
I've heard horror stories about cleaning a once soldered joint. Thankd guys.
...mainly about getting them clean. that re-soldering would be difficult if not meticulously cleaned.
Horror stories like what? Once the joint is separated you can take a file and knock down any high spots that would prevent the pieces from going back together when cold. Clean it up with emory cloth like you would bare copper and if anything it creates a better joint because the copper pieces are now already tinned with solder.
My dad would always re-use copper fittings and I've done the same thing several times without any problems.
