Hello, I wanted to see if I could get some ideas to stop my sprinkler from draining water out of the line and flooding the yard after the water pump has shut off every time. I have an aerobic septic system, which is operating fine overall, but an ongoing issue has been that the 2nd sprinkler head that is furthest from the septic system keeps draining all the water out of the pipe, since it is the furthest downstream and is also downhill, so gravity keeps feeding water to it for at least 20-30 minutes after the pump has already shut off. It is flooding the yard in that area and making it total mush, which is impossible to mow because the grass and soil is completely soaked all the time.
I tried installing a spring one-way check valve in-line, directly below the sprinkler head itself. I thought the valve would stop water from continuing to drain from the head after the pump shut off, since it would not have the pressure of the pump, but apparently the gravity (and perhaps siphoning action) is too strong, and unfortunately it continues to behave the same way. I added an image of the in-line check valve that I used, as well as the type of sprinkler head that I have.
I did also consider trying a different type of head, perhaps one that does not have drain holes (if that exists), but it seems that other types will not put out enough volume.
Just to be clear, the pressure after the pump shuts off is not so strong that the spray head continues to stay up. When the pump shuts off, the spray head goes down like normal, but there are drain holes at the bottom of the sprinker assembly that the water continues to drain out of for a very long time. I think if those drain holes were not there then it would just come out of the top instead, but without raising the spray head.
Thanks for any input and suggestions that you can offer!
