SER cable size and plug question
marubadu
I had a rough inspection on my electrical and he passed the trench part. He told me to put 15 amp tamper proof plugs on my 20 amp out let circuits, which I thought was weird for a shop. Is that okay? seems like I'm missing some capacity if I do that.
On the advice of friend who's a master electrician, I ran 1/0, 1/0, 1/0 aluminum wires through 140-ish ft. of conduit with #8 ground. (PITA to work with.) He (the inspector) told me to just put a 8"x8" junction box and splice in service wire to the panel to avoid running conduit. I only found 1/0, 1/0, 1/0 aluminum SER with a 2 or 3 ground. Is that okay or do the grounds need to be the same #8?
I'm not an electrician, so there's that.
Bert_
NW Iowa
20 amp plugs are a waste of money most of the time. Do you own any tools with a 20 amp end? Because that is the only reason to have a 20 amp plug.
Transitioning to ser could make sense if you have a long run on the inside of the building and it's hard to run the conduit. If it's just a short ways I'd probably just do it in pipe and eliminate a splice.
Yes, it is okay. NEC allow 15A outlets on a 20A circuit. I have only ONCE seen a device that had a NEMA 5-20 (120V@20A) plug (it was a 20+ yo computer server).
I think the whole tamper resistant outlets is a scam by the equipment manufacturers to increase their revenue ! I grew up without them. My children survived. My GRANDCHILDREN have survived !! Its a SCAM !
Personally, I would run the conduit inside and terminate at the load center.
marubadu
I don't recall ever seeing a 20 amp end ever.
The reason for switching to ser is that it's super tight in the house to the panel.
sberry
Brethren, Michigan
Yes, they do that to prevent the janitors from using the general circuits. I saw one in a school a while back, the vac had the factory 15 end cut off and a 20 installed. It was a light vac and the main problem with it was the cord was too short to reach the dedicateds so someone twisted it back to fit 15 outlets.
