Serpentine belt tool
ajchien
Los Angeles, stuck on the 60 freeway.
Well, Id like to change my serpentine belt on a honda 03 crv. belt tools from GW are $60 and from HF $20. I'm kinda cheap.
The two wrench interlocked trick doesnt seem to work, since Ill be pulling clockwise instead of counterclockwise.
Has anyone considered taking a wrench, putting the box end on the tensioner, and duct taping a 1/2 in breaker bar inserted into the 14mm open end as a makeshift tool?
Or maybe I should just get a sepentine belt tool.
mrholeshot
MEMBER EMERITUS
I have the Gearwrench serp tool I bought 7 years ago. One of the best investments ever. About 50 dollars. I havent seen much it wont work on.
Theloniousmonk
Where the tall corn grows!
If you are using the tool ONCE, get the HarFreight/Performance Tool... if you plan on using it more than ONCE, get the GearWrench. Lisle used to make a decent bar/handle, don't know if they do anymore.
Don't forget to get the serpentine belt/pulley laser alignment kit too!
If you can fit a ratchet in there, then maybe picking up a long extension/breaker would be a better investment since you can use the extension/breaker for many other things.
Danglerb
SoCal
First make sure a long breaker bar and a socket won't do the job, then I would consider the HF. The "tool" is a flat steel bar a couple feet long with a 1/2" drive nub on one end, and some crowsfoot wrenches.
Shadowdog500
Down the shore
How are you locking the wrenches together, that they only work in one direction,
I usually lock the box end of the wrench i am pulling on to the open end of the wrench that is on the bolt and never remember there being an issue.
I also tend to use a socket and a breaker bar for tensioners.
Chris
Fedwrench
Valley of the sun
For infrequent use, the harbor freight model should work well. I think it's often on sale. If not there's the ever popular 20% off coupon. Check Ebay for one. You could also buy your belt at Vato Zone ( it would be a pos belt though) and borrow one of their belt kits from their loan a tool program.:beer:
srmofo
SW ohio
use some worm/hose clamps to hold the breaker bar to the wrench. Nut driver or socket to get them nice and tight.
I used to use my gearwrench set all the time, but its getting tough to use on some of the newer vehicles.
scott37300
Wisconsin
Can you explain some of the issues on newer cars? I also have the gearwrench tool and it's worked good on everything I've tried it on. But havent' had to try it on any newer vehicles yet. What tool do you use when the gearwrench won't work?
Goinlow
Why don't you make a tool? Get a wrench and cut the box end off and weld a long piece of steel or another wrench to it. I made a tool for the serp belts on ford 3.0 engines in taurus's
srmofo
SW ohio
clearance between the frame rails and the tensioner. I usually resort to a combo wrench and some good ol' elbow grease and nut buster grunting. Keep in mind I usually change at least 1 belt a day and I work in an independent shop so I see all makes and models. Still a great tool, dont get me wrong but those pesky engineers keep making my job harder and harder
A
ajchien
I'm an idiot, @Chris - yes the two wrench trick does work. I was just fiddling with it the wrong way.
However, after test fitting it, I still might get the HF tool. I don't think I want to be pulling on a slightly wobbly two wrench set up while pulling on a belt at the same time.
All my regular ratchets and breaker bars and sockets/crows feet simply don't fit in the tight space.
Toolhorder
Montana
treasureseeker
I have a 2003 Accord and have the same issue with no room for general mechanics tools and used the two wrench trick. I don’t do enough mechanic work to warrant buying the Serpentine tool.
Toolhorder
Montana
Yeah I worked at the dealer so it was cheaper than the OEM tool to get the Matco. OEM tool is made by Snap On actually and then Honda marks it up and then my dealer charges me 10% so I just got it from Matco.
HandyManny
Out West
Buy the special tool. It may cost you as much as the belt itself but it will be a hell of a lot cheaper than paying a mechanic an inflated price for changing out your belt. Some will charge you by how many pulleys you have, believe me. As long as you drive a vehicle that has a belt you'll find that tool handy in the future too. Hondas tend to last a while so you might get a good 4 uses out of that tool on one vehicle, but you'll also have it for the next one too.
Professur
Mo-Ray-Al, K-bec, Ka-Na-Da
The tensioner on the '93 Caravan 3.3l is a chrome plated beach to get to as well. My longest 15mm barely makes it. Any longer and it wouldn't sweep far enough to release it, any shorter and there wouldn't be enough leverage to move it at all. I came very close to drilling a hole though the inner fender to get a socket in there ... but couldn't figure a way to pull the bar, and reach the belt at the same time without lying under the wheel.
A
ajchien
Thanks for all the opinions. I did my belt yesterday. I wound up putting the box end of a 14mm combination wrench on the tensioner, and then putting a 1/2 in drive 15 inch length breaker bar into the open end as extra leverage.
