Service lines through floor Joist
zendriver
Indiana
Can they be run through wood floor joists? If so what is the maximum amps and proper hole size?
Trying to figure the best route for hundred amp service to a garage subpanel
Thanks
sberry
Brethren, Michigan
Depends is the answer. You cannot weaken the structure, 1 general rule is not in the center 1/3 span of the joist. Amps are irrelevent.
Norcal
The issue is where you drill the holes & how large the holes you drill, what size are the joists?
Don1357
Palmer, AK
I'll answer this question! The proper hole size is 3/4, too small a hole can cause stress on the cable.
I could be wrong but if I so it will get you an answer faster, some people around here just love to jump on a wrong answer :D
Bert_
NW Iowa
It's not a service, it's a feeder.
Yes it can be run through joists. The hole size depends on the size of cable or conduit that needs to fit though.
Z
zendriver
Indiana
I forgot to measure the joist but I think it’s 8”
Itdidn’t occur to me to have more than one hole, which makes sense from a wood stability Standpoint.
I have an electrician coming over tonight will take a look at what i want to do and go from there.
Thanks
Bert_
NW Iowa
Thanks
How do you run a single cable through more than one hole in a floor joist?
