hotrodA
I have 100A service to my detached shop from my 200A house panel which has a breaker for it. The detached shop has a 100A panel with main breaker also.
I want to continue 30A, from the 100A panel, 120 feet, on to an additonal detached bldg for lights and recpt. 10/2 (?) on its on breaker.
The first 80 feet on this run will be indoors, but last 40 feet will have to be buried in PVC.
My question is/are:
Will NEC code allow me to split the indoor and outdoor wire at a junction box either inside or outside the first bldg. before the PVC, and then split it at another box for the light and recpt circuits at the 2nd detached bldg? Or do I have to run continuous outdoor all the way? Does the service connection have to be uninterrupted?
And/Or can I add another sub panel in the last building with the two breakers for lights and recpts, for a couple of T-12's and table saw.
Also looks like a 2nd (or double) ground rod will be needed, right?
Suggestions, Please. Thanks!
My question is/are:
