Greetings guys and gals, this forum has been a huge help
I just picked up one of these:
Puma 7.5-HP 80-Gallon (Belt Drive) Two-Stage Air Compressor (230V 1-Phase) for a great price locally. It is used but functions excellent.
The pump and motor are rated at 100% duty cycle, so it should be up to the task of filling both tanks when needed.
I have a 80 gallon Quincy horizontal tank that is now extra.(ASME 200 PSI rated, it originally had a 2 stage 175 PSI Quincy QT10 compressor pump installed, but now its just the tank, check valve, and pressure guage.
The Quincy tank has a 1" inlet on top, with a check valve still in place (if I need to use it) and 2 x 1/2" outlets on each side of the tank. It also already has casters I installed, so moving it around is simple. It also still have a pressure guage (300 PSI) installed on it.
So basically I am asking what flexible hosing and fittings I would need that are rated for the PSI this pump will be exerting. I already have the plumbing figured out as far as how the thank will share the air.
Thanks in advance for the help
