Seville Cabinet Custom Sink Install
bpaetznick
I wanted/needed a sink in my garage to wash up and misc but didn't want a big tub sink so I came up with the idea to use one my spare rolling Seville cabinets. After taking some measurements I figured a 12"x18" sink should fit and I also found one that was 10" deep which would be deep enough to clean paint rollers and stuff. See pics of the install, I think it came out great and it looks like it is part of my cabinets. I use the drawers for towels and stuff and there is plenty of room underneath for storage of larger items. All that is left is the towel and soap dispenser. I want to add a matching backsplash if I can get Seville to send me some material.
bpaetznick
Googled the size I was looking for and ended finding the best deal at Crest Restaurant Supply. It is a Krowne Metal (HS-1419). Pretty expensive, almost $175 but it accomplished what I wanted it to do. There are cheaper ones but I wanted the deep sink which cost a premium.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Are you going to coat the top with some polyurethane or something similar? If you don't, it'll look pretty nasty after a while.
bpaetznick
I suspect the "mobile" part is just to match the other cabinets. Obviously it can't move or the supply and drain lines would be an issue.
Definitely not mobile. But I can disconnect the lines and roll it out of the way if needed.
bpaetznick
The Seville tops are coated from the factory. It still has a good coating on it despite the use prior to making it a sink cabinet. I caulked the sink heavily around the rim to make sure nothing gets through to the bottom.
