Seville Workbench Build
Beowulf
So I just put the Seville Classic workbench together.
Here is the unboxing.
Screw inserts into the top that will hold it down to the supports. All of them where drilled to a depth of .8" to .9"
Here are the supports laying on the top.
A shot of the threaded inserts through the supports.
Here is how it was supposed to be secured per the supplied hardware.
Here is what I did. I went and got 25mm M8s and 5/16" lockwashers. Then I cut 3" strips of barstock and drilled a 5/16" hole. Then used the supplied flat washer, the lock washer and the barstock. Overkill? Yes. Peace of mind. YES!
Here it is standing up and put together. Since it did not come with lock washers I used them on all locations not just for securing the top. There were 26 M8 fasteners. Only 8 hold down the top. Also, per the pics of the top upside down you can see there is a difference of overhang from front to back. You can either install it so the legs are out front with only 5/8" overhang or you can flip the legs around and you will have several inches of overhang. I chose to put the legs out front. I did this for three reasons. One I wanted any tool chest under the table to be flush with the legs. If it was further back, the drawers would be obscured by the top and make it harder to get things in the back of the drawers. Because the whole chest would be further back and closer to the wall, but top would be in the same place. Second, I wanted the leg support to be right under my vise instead of it being mount out beyond the supports. I could see me doing something stupid and actually snapping off the corner of my table. Third, I'd rather have the space behind the bench where I can use it. Back there I will most likely store good pieces of cardboard, wood,...etc. It is only a few inches between the legs and the wall, but still I will use it.
Next I plan on using some 1-1/2" angle iron to bolt it to the wall. I will inset the angle iron the depth of a 2x4 under the top. Then I will bolt the 2/4 to the wall. The top will slide over the top of the 2x4 and then the top touches the wall the angle iron underneath will just be touching the 2x4. This way I don't need to worry about lining up the table and the holes in the angle iron to a stud. The 2x4 will be doing that.
Overall I am happy with the table. I am not happy with my very angled floor. I had to raise up one end about 2.5cm. It makes it look like my rolling chest is broke. I will most like build a support system under the table similar to Steevo's Harborfreight tool chest workbench build.
P.S. Yes, I know that vise is not worth of the vises of GJ thread. I am desperately trying to find a Wilton 1755. I think the 1765 will be too big, and feel a 1745 might be too small.
http://www.garagejournal.com/forum/showthread.php?t=126086
K13
St. Albert, AB Canada
Looks nice! I am a little confused by the addition of the bar stock as the weakest point of that top attachment is going to be those inserts. They will pull out long before any damage was done to the steel frame.
Beowulf
I'm not disagreeing with you. I just did not like the little bit of flex I saw in the top supports, which I thought might relate to a slightly less sturdy finished product and having holes bigger than the washer size just bugs me. Even though this table was rock solid and 99% of all forces will be straight down or tortional from yanking on stuff in a vise, I just wanted that little bit extra. To tell you the truth, I think the top would have been more secure if it only had pre dirlled holes sized for 3/8"x1.5" lag bolts. I know having the thread inserts will make it so it can be disassembled over and over without degrading the hole, but I never plan to do take it appart.
Back to your question. With the vector force at play, it really is not neccessary to do what I did, but it was fun. Now I will say it was 100% necessary to use lock washers though. With all the hammering, grinding etc, I knew those bolts would loosen over time. I almost used Locktite, but upon looking for it during assembly, I reallized I ran out during my last project.
KEH
My understanding is that wooden tops need to be a little loose because the wood will expand and contract with changes in humidity. If it is held tight it may crack.
KEH
Beowulf
I'm hoping the groves they cut on the bottom will take care if that.
71goldss
Northern Calif
I've had that same workbench for about a year now. Very happy with it so far and you can't beat the price!
About the wood top. I've noticed that my top has become more wavy on the surface over time. When I'm wiping down the surface, it's not as smooth as it was when new. Where the grooves have been cut in the bottom, the top now has deeper valleys directly above the grooves. The valleys were there when new, but are much more prominent now. I'm assuming the wood is either curing or expanding and contracting with the humidity as previously mentioned.
Pate
New York
I recently bought the same bench and am very happy with the quality. I also bought A bunch of the Seville cabinets. Assembly is time consuming, but like the look and quality.
Magneto
"Relocated from VT to Middle TN"
I'm with you. I also just bought the whole series of Seville Ultra HD components. It's great for a home shop....and you can't beat the price compared to others of the same quality.
allinon72
Indianapolis
Nothing wrong with beefing up the way it goes together - build-it-yourself items like this are often built for ease of assembly, not sturdiness.
