hallboyone
I know that this method of organizing tools always gets mixed results but I have a small enough collection that I can justify the time. I used foam insulation. Here is the link http://www.homedepot.com/p/t/100320340?catalogId=10053&langId=-1&storeId=10051&N=5yc1vZbaxx&R=100320340#product_description. $12 is pretty cheap and two sheets would shadow the largest tool collection. To mark the tools I laid them out and put a bright light about two feet above each one. You have to move the light each time to keep it centered over the tool at hand in order to insure a vertical shadow. Then you simply trace the shadow. To cut it of a used a dermal with the multi purpose cutting kit. As long as you went slow there was very little melting. I set the depth of the bit by holding the tool up to the bottom of the fence and adjusting it until the bit just barely was beneath the high point.
I was a little worried that I would end up with a lot of slop but as you can see nothing but the upper 3/8" has any noticeable gaps and that one only has gaps because I upgraded from a craftsman to a Wright. That leads me to the biggest problem with this technique, what if (when) you get a new tool. There is really nothing you can do which is why someone might not like it. Oh and one more thing, be sure to cut a finger hole to get the stuff out with. I failed to do this on a couple of tools and now it doesn't look uniform
. Which is important of course.
Of subject but I thought I might ask. Do any of ya'll use silicon moisture absorbant products is your tool chests? Might be a easy way to fend of rust.
