"Sharkbite"-type connector for EMT
strutaeng
Dallas, TX
I just saw these at my local store.
https://www.homedepot.com/p/Southwi...ERCH=REC-_-pipsem-_-309278491-_-309277844-_-N
Are they a new thing? They resemble the sharkbite-type plumbing fittings. They did say water-tight on the packaging, so that's good.
In areas where conduit is exposed I like working with EMT when possible. Looks a lot better than PVC conduit, although slower to work with.
They are on the high side on price, but just like the sharbites, installation is a breeze.
Has anybody used these?
rande
The description says "designed for use in dry locations only".
Platonic Solid
CT-USA
MattT
I've been having problems with homeless depot links on here for a while. Sometimes get a blank page and sometimes it goes to their homepage instead of the product page.
Regards these "sharkbite" fittings they're expensive and look clunky compared to raintight compression fittings.
LXCam
Doesn't look like it's working. Here's a Snipping image:
How is that even flipping legal. Per code the conduit must be bonded, so does that fitting have some crazy method of bonding the conduit?.
oop's never mind. They look to be PVC but are powder coated aluminum.
rlitman
Long Island
The links work for me. On the page it says:
No tools, no adhesives, no threading
Maintains ground
Removable and Reusable
Norcal
There was a push in/ one shot EMT connector made by Sierra/ Tomic but do not know if they are still made by a successor company.
strutaeng
Dallas, TX
Yeah, I saw the "maintains ground." It's made by Southwire, so I'm assuming it was developed by R&D, tested, approved and whatever...
I'm guessing the dimensions/tolerances make it such that this DOES NOT fit PEX, otherwise some idiot will invariably use PEX for conduit, LOL. Or, other way around!
Norcal
fetch
This is a Tomic brand 1/2" EMT fitting
Showkey
"MEMBER EMERITUS"
Wausau WI
The disadvantage cost !!!!!!
The problem is $3.38 per connection. Larger project you could spend $100 in connections.
Metal set screws are .37 per connector.
Similar to the plumbing where they run$3-$9 per, one or two connections in DIY install or repair and DIY want to avoid solder then it makes sense......but......larger project, quantity purchase of the conventional connectors makes more sense.
mike93lx
Richmond, VA
Emt connectors are incredible simple to install already. What is the benefit?
Plumbing is a different story. Avoiding soldering has benefits, plus the connectors can be rotated after installation. None of that is a factor with emt
MattT
Except that your doing hack work by doing so. Code requires that the conductors be pulled after the pipe is installed
Code or not pulling wire before the conduit is assembled risks damaging insulation and pinching wires. And the sharkbite style locking spring probably increases the chance of cutting insulation..............
strutaeng
Dallas, TX
IF the original poster needs watertight fittings, they have a hex that is easily tightened with a pump pliers.
There is no such thing as a watertight set-screw connector/coupling that I'm aware of.
Yeah, THDs around here don't have the raintight EMT fittings. I installed a subpanel and the I had to get a raightight at the electrical supply house. At least they have that option now.
But agreed, a basic set screw will work for me for indoors.
Just found those fittings "interesante!"
Norcal
For rigid/IMC there are Midwest “Rainboot” fittings which are set screw type.
Jim greengo
Behind my house
I dont see a nut that can be tightened up on that fitting.
If you're working on something that's going to get wet compression connectors have been around for 50 plus years.
