I've been using a Drill Doctor for five years. I get excellent professional quality results. But it took a ridiculous amount of patience persistence to finally get good results. In fact, i finally called the factory to find out how to set it up. The big problem with the unit is the instruction sheet lacks critical information. Once I found out how to set it, the unit became very efficient. I get result that are every bit as good as I used to get with the Darex I used at work.-That's a rather wide range of items and materials. You ought to have a budget in mind as that will define what machine to be shopping for. You can simply buy hand/bench stones on the low end of cash or spend thousands for industrial machinery capable of doing about anything. You also haven't stated your experience or abilities and that makes a big difference in what you'll be capable of using. You absolutely have to understand cutting tool geometry or nothing will work at all or work properly. A few words about your intended items to be sharpened:
Drill bits- Just about any bench grinder will do, unless you're going for drills larger than 19mm. A carborundum wheel will be ok but doesn't grind as cool as an aluminum oxide wheel. How well you dress the wheel will determine how good an edge you create. Sharpening drills free-hand isn't difficult but is made easier/better with jigs/fixtures for this.
Masonry bits- Carbide can't be sharpened with the same wheel used for steel, carbide is too hard/brittle a material. There are silicon carbide wheels, often green in color, that can grind carbide but they leave a ragged edge that's not very strong. A diamond wheel is what's used for carbide. You don't want to breathe in the dust from carbide, it's very bad for the lungs.
Knives/Scissors- I always sharpen these by hand with bench stones although there are many jigs for doing this. My stones are a mix of India, Washita, and Arkansas used with oil on the stones to prevent clogging. I use water stones for the Japanese swords but that's an entirely different subject.
Drill sharpeners for HSS only:
Drill Doctor- All of them I've used flatly **** and aren't worth the purchase. Anything similar probably not worth it either.
Darex- Works well provided they aren't worn out. Short learning curve when you first get one to achieve good results. Expensive
Black Diamond- Also work well and achieve professional results like the Darex once you learn how to use it. Expensive
Oliver- Older industrial grade machine I've used on larger drills with good results. Not as expensive but rather large floor models
Industrial cutter/grinders- Many brands that are large, expensive, 3 phase electrical, and can sharpen about anything you have.
Surface grinder- My personal favorite but overkill for the average homeowner. Not terribly expensive but dangerous to learn with.
-I haven't used/seen every model that they make but the one purchased at work was by someone unqualified to make that call, a painter. The unit that came in was almost entirely made of molded plastic, even the reference surfaces. It flexed, took an unequal amount of material off either side, and seemed destined to wear out in short order. Everybody has a different idea of what's acceptable, most people feel that if it produces a moderately sharp edge with a shiny surface finish then it's good enough. I don't demand a drill grinder be capable of producing +/- concentricity of .0005 but this model was likely .005-.007 off concentricity and that may be ok for Harry Homeshop but not acceptable for shops I worked for. The over-use of plastic on reference surfaces that will combine with grinding dust will abrade into the useless POS even the painter had contempt for after a few sessions.I've been using a Drill Doctor for five years. I get excellent professional quality results. But it took a ridiculous amount of patience persistence to finally get good results. In fact, i finally called the factory to find out how to set it up. The big problem with the unit is the instruction sheet lacks critical information. Once I found out how to set it, the unit became very efficient. I get result that are every bit as good as I used to get with the Darex I used at work.
Would appreciate knowing what you found out; Thanks.I've been using a Drill Doctor for five years. I get excellent professional quality results. But it took a ridiculous amount of patience persistence to finally get good results. In fact, i finally called the factory to find out how to set it up. The big problem with the unit is the instruction sheet lacks critical information. Once I found out how to set it, the unit became very efficient. I get result that are every bit as good as I used to get with the Darex I used at work.
The angle for setup is not correct as marked. You need to go backward into unmarked territory.Would appreciate knowing what you found out; Thanks.
