Shear Brake Roll question
RivennHewn
PNW
I have a Jet SBR 40N that I am trying to get tuned up.
On the shear, it cuts good for the 1st part of the cut, then just folds the metal.
There are 3 adjustment points. Two on each end of the table, and 1 center on the back.
My problem is that is cuts fine at all three adjustment points, but between the points it wants to fold.
Any ideas?
Bill Bowman
Metro Chicago
Any ideas?
I'm assuming it's a 40" shear? Is there a way to shim the shear head closer to the table? Usually, there's an adjustment to bring the whole shear head closer to the table, and then back off the 3 adjusters. Maybe a picture of your shear? Bill
theknurl
SoCal
Its flexing.....how thick is the sheet you're trying to cut? and what is the shear rated at?
R
RivennHewn
PNW
The shear is rated at 20G.
I'm cutting 22G mild and some 20G zinc.
The main adjusters are on the table, with a fine adjustment screw on the back of the upper blade.
I've made several attempts at shimming with brass stock and paper of different weights.
R
RivennHewn
PNW
Pic 1; shear w/ hold down removed
Pic 2; Adjustment point at each end. Adjustment screw is on bottom side.
Pic 3; Upper cutter as close to lower cutter as I can make it, and still pass by.
Pic 4; Backside adjuster screw.
Pic 5; Clean cut paper at all three adjustment points.
Pic 6; Folded paper from between adjustment points.
Any ideas would be greatly appreciated.
Thanks
