Shear wall studs - sistered 2x4's or 4x4?
FordTruckWench
California
This is for a shed. Someday it may become "part" of the house, so I want to build it to full earthquake codes.
Earthquake holddowns require at least 3" x 3.5" material. It is acceptable to build this up by sistering two 2x4's. Earthquake shear wall sheathing needs its edges to bear a full 1.5" on the framing. Once again, this implies a minimum of sistered 2x4's at each plywood seam.
When using two sistered 2x4's at panel seams, this means that the sheathing seam will line up exactly with the 2x4 seam! This creates both a weak spot and an air infiltration spot. Therefore, I'm thinking of using 4x4's at all sheathing seams. However, it seems that standard practice may to simply double up 2x4's. Perhaps composite (built up) members are more stable than solid members because of multiple grain arrangements.
So, sistered 2x4's or single 4x4's?
A related consideration: I saw a video or read a website mentioning a new idea for earthquake framing. A 4x4 "block" should be installed between consecutive studs at the middle level of the wall. This is sort of like fire blocking, except that the purpose is to keep studs from twisting when a shear wall is racked. It would be easier to install these blocks if all studs are 2x4's, i.e. no toenailing required with a bit of planning ahead.
duneslider
Riverton, Utah
In my house there were areas where the engineer called out 4x4's, 4x6's, and stacked 2x4's (one location has 5 2x4's). Anyway, my understanding is that a 4x4 is superior to a double 2x4 but I don't know any of this for sure. I just don't think they would call out a 4x4 if double 2x4 would work but in one case when I did the walkthrough with the engineer there was one location where we needed 2 2x6's and I was told that putting them in an L configuration would be just as good as side by side. So, what I gathered is that there are multiple ways to skin a cat. I would guess in your condition either member would work but it sounds like the 4x4 would help you with air sealing maybe... Really though, unless you tape/caulk that seam air will still get in, I really don't see the 4x4 helping much with the air sealing.
