Sheave wear caused by old belts?
shooon
Dawson Creek, BC
Can V-Belts harden and create wear on sheaves as they age? Someone mentioned this to me and I've never heard of it before.
Background:
Where I work, we have 18x 25HP ariel cooler fans used to cool glycol installed outdoors. Each fan has 8 belts that are 5-6 years old and have been exposed to the elements. No signs of cracking, just appear slightly glazed and hardened.
ForceFed70
BC, Canada
Seems a stretch to me. Unless the belts are reinforced with steel wire, the sheave material should be much harder than the belt material - regardless of age.
Sheaves certainly do wear - especially when sand/grit intrusion occurs. What material are they made of? Aluminum?
A_Pmech
IL
Abrasive material embedded in the belt and belt slip will cause sheave wear.
derkperk
An old belt is likely worn thinner than a new one, unless it has perfect alignment. As a rubber belt ages, raw edge or wrapped, it will harden causing it to slip. The slipping WILL wear your sheaves and pullies.
Belts are a lot cheaper that 8 groove pullies.
Sent from my XT1565 using Tapatalk
dw1
Ky
Alignment, that's what I would check if they are wearing.
