Shed build 10'x16'
Modeler
Mid-Willamette Valley, Oregon
Hi all,
Joined a few days ago, thought I'd take a few minutes and post a build thread with my latest project.
A little background: My wife and I have been married for 1 1/2 years. She was previously living in a 1,200 sf townhouse, but we decided that it would be best if she moved in with me rather than me moving in with her. I have 5 acres and two houses (one is a rental), the downside to that plan is that my house is only 800 sf; the result has been a second bedroom filled with boxes and a 5x10 storage unit in town costing us $70 a month. I recently sold some things that netted us a few thousand dollars, so after paying off the last of my debt we decided that it would be a good idea to build a shed to replace the storage unit and have a place to keep general garden stuff. A side benefit is that I will get most of the garage to myself, which she wholeheartedly supports; she wants me to have a space to build things and work on projects :thumbup:
Local code allows us to build a building up to 200 sf and with an "average roof height" no more than 10' above the finished floor without a permit; we decided 10 x 16 would be a good balance of size and cost for the space we had.
Last Wednesday I started by digging out holes for eight 10" diameter footing/piers. Local code requires footings to be 12" below finished grade so I dug them down a few extra inches, filled them with gravel (and tamped it all down), then suspended the 4x6 skids over the holes and poured the concrete into 10" sonotube forms. A rented laser level ensured that everything was perfect, and the tops of the 12" tall footings are just at ground level (That took up all of day 1).
After that a friend admonished me for not scraping the sod first. He was right, so I ended up renting a skid-steer and doing it after the concrete went in, hand digging along the edges and putting down landscape fabric and gravel. I should have done that before pouring the footings. Live and learn...
Next came the floor framing, PT 2x6 at 12" o.c. with blocking and doubled joists at the ends:
I ended day 2 by putting down the flooring, 3/4" T&G fir plywood that had been painted with Kilz primer on the underside to discourage water absorbtion:
By day 3 there was a storm brewing; I spent all day working in the rain to get the walls up. Standard 2x4 framing, 16" o.c. on the side walls and 24" o.c. on the end walls. Corner posts are 4x4's as are the posts framing the 6' wide door opening. The east wall (left in the photo) is framed for two 2'x3' windows and the south wall (far wall in the photo) is framed for a single 3'x3'. The north wall has a header (doubled 2x6's with 1/2" plywood) spanning the whole thing to support the roof framing. Sheathing is 5/8" T1-11 fir plywood with 4" grooves; there will be no OSB in this shed. I made it this far before running out of daylight:
That was Friday, I had plans for folks to come over and help frame and sheath the roof Saturday but a storm hit a little earlier than expected and I didn't feel safe standing on a ladder with a 4'x8' sheet of plywood in 30 mph winds:scared:
It's now Monday, the storm has been raging off and on all weekend but the weather is supposed to improve starting this afternoon. The radar shows the current shower should move through within the next hour or so; I'm hoping to spend the afternoon framing the roof and getting the rest of the siding on.
Modeler
Thanks JC!
The rain finally let up and I was able to get out there this afternoon. It was slow going working by myself, but I was able to get the 2x8 ridge beam, 2x6 rafters and 2x4 collar ties in place before the sun dipped below the oak tree in the field.
Tomorrow I'll get the gable ends framed and the rest of the siding up along with the fascia boards and if I have time the roof sheathing. Lots of heavy lifting to be done tomorrow, I'll have to enlist the wife to help!
Kaikman
Nice! Just getting started on my 10x16, as well! Good luck and keep us posted.
Modeler
I was able to get out for a few hours yesterday after the rain stopped and get the siding up on both ends, the front door cut (7' tall x 6' wide) and get the front gable end framed and sided.
Today I was able to get out for a few hours this morning at get the back gable end framed and sided.
The gable ends took a little more time than I expected, there's lots of marking, cutting and fitting required. Tomorrow I'll get the blocking in between the rafters and get the roof sheathing on (hopefully).
I'm quite proud that I remembered the z-flashing on when I sided the gable ends, that's pretty good for me! And in case anyone is curious, I used 2 1/2" 8d stainless ring shank nails for the siding. No rust streaks for this shed!
Modeler
Last post for a few days...
I was able to go out and get the roof sheathed yesterday afternoon before work. 1/2" CDX:
An inside view, 2x8 ridge beam, 2x6 rafters and 2x4 collar ties with framing for a 3'x3' window in the end and a pair of 2'x3' windows on the east wall:
Modeler
Significant progress today! My friend came over and helped me get the roof on. Nothing special, regular 3-tab shingles over 15 lb felt, but it looks good and should be watertight! He also brought a coil roofing nailer, which was extremely handy to have.
I was also able to spend some time inside today. I had originally put the collar ties at the level of the top of the wall, but today I decided to move them up the rafters a bit. Apparently you can move them up a maximum of 1/3 the length of the rafter, so I went ahead and did that. You can see some light coming through the rafter bays; I was hoping to install blocking today but it didn't happen. I'll get right on that tomorrow.
(The photo is a little blurry, but you get the idea)
Modeler
I made it back out this afternoon, the rafters are fully blocked and the doors are built. I also spent quite a bit of time cleaning up the worksite, I chopped all the offcuts >14" up into kindling and moved the trailer away. Swept up the shed (a lot of sawdust and nails) and moved everything inside. I left some scrap plywood down for mud abatement:
Here's a shot of the interior now. Everything has been moved inside and is out of the rain. In the back you can see the doors that I built today with the cutouts from the doorway used as the door siding. On the right is a stack of 1x4 SPF for door and window trim and a piece of 5/4x6 SPF to go over the doorway.
I -might- get the doors hung tomorrow, we'll see. Work week starts again tomorrow night.
thill07
Shed looks good. I'm thinking that may be about the size I'm looking to build. Of course I could always go bigger...lol.
Modeler
It's been a couple weeks since my last update....
My main issue with getting it done has been weather and work. I work 4 days on and 4 days off, so I only get 2-3 days a week to work on it. Combine that with the fall weather at my house (fog every morning until noon) and I've only had a few hours every day to get the painting done.
I've learned a couple things: T1-11 is a pain to paint and untreated T1-11 soaks up the first coat! I used Olympic Icon (paint-and-primer in one, good for application down to 35 degrees) and I was only able to get around 120 sf per gallon for the first coat. The wife chose red for the walls and white for the trim:
Shown above is the first coat, I started with semi-gloss but didn't like how it showed the grain. I took the last 1 1/3 gallons of semi-gloss and mixed them with two new gallons of flat to come up with the top coat (shown below).
Most of my time has been taken up by painting when I'm able, but today I was able to get the doors hung. Here's the first door (this one will be latched from the inside):
This end of the shed (doors and surrounding wall) have the topcoat applied (the other three walls haven't yet). I used some gate hinges to hang the doors, the trim is 1x4 SPF and the large bit of trim over the doors is 5/4x6 SPF. I had a problem in the upper right corner, the hinge has been taken out and will be replaced tomorrow. I hung all the hinges with lag screws, but I think I'm going to back those out and replace them with galvanized carriage bolts. It should be stronger that way.
Here's a shot with the doors open. 2x4 framing, 1/2 plywood corner gussets. I'm setting it up so that the doors are fully supported when they're closed which should prevent wracking and sagging.
That's all for now, I'm at that stage of the build where I spend a lot of time doing things with not much outward progress to show for it. Door latches and gable vents tomorrow!
