kckndrgn
I have a 14x20 shed that is used as a camping/hunting cabin. So I put insulation in, and I'm guessing I did something drastically wrong because now in the late summer/early fall (when we want to use the cabin the most) everything inside becomes moldy and covered in gunk.
The shed is the standard "Amish" type pre-fab with shed doors and not a man style door, 2x4 construction all around.
I put in R-13, kraft faced insulation on the walls and ceiling. I think, now years later having learned a lot more, the insulation on the ceiling is what is wrong.
There is no ridge or soffit vents, the only vents are gable end vents.
So, if I pull down the r-13 insulation from the ceiling, how should it be insulated? Cost is an issue, we also have no electricity at the cabin, so I can't run a dehumidifier while we are not there.
I have been told to just get a solar powered vent fan and let it run while we are not there to help, not sure how much good it will do though.
