SHED DOOR
MT800
Montana
I would like to pick the collective experience of the members. Here is the problem.
I have a cold storage shed (where I live everything is cold storage!!) behind the garage. It just has a walk door, and I would like to install a 4' door
of some kind. I want to put riding mower and snow blower in the shed. Let me say this, the snow will block a swinging door, don't really want to sacrifice the floor space to swing a door inward, there is not room to run barn doors and roll up doors only come at 6' tall. I have a hard height of 84", not enough to raise roll up. It doesn't have to be snow tight, but I need more than a plastic sheet!!! Maybe even a way to lock the door, although we rarely lock the walk door. I don't mind some kinda threshold, I can drive the mower and blower over a short threshold .
Any questions and comments and ideas are welcome.
engineer2
Chicago burbs
I build my own double door with a total width of 4 feet. Clearing snow it isn't too bad.
Inside is OSB. It's weather-stripped to keep the mice and snow out.
Right door has a storm door closer. Left door has a cane bolt to hold it open.
If I had to do it all over again I would have made it a little wider.
readhead
Durango, Co.
On our sheds with roll up doors the roller part was actually above the ceiling joists. Is that an option. Roll up doors can be ordered for any height.
Steve W.
Southwest oHIo
No ideas here about what style of door, just a comment that it must be a rather small riding mower to fit through a 4' door. :unsure:
My walk-behind mower is 4' wide. :dunno:
bbxlr8
Eastern PA
I'm the KISS type & in snow belt (ugh). Designed my 12x38 for a specific space over 18 years ago, and moved it once since then. Have both styles: 8' - roll up on one end, man door near it on the side. Then did 2x version of style in @engineer2's pic (very nice BTW) (2 x 4' doors) in the middle of the far end on the same side as the man door: designed to accommodate side entry of ford 3 cyl w./60" mmm w/fixed ROPS.
Still very happy with it and no real issues other than don't let it freeze up and set. I generally only clear the ramp and swing area.
Actually debating adding an 8' on the far other end after moving & leaning towards swing style for cost and simplicity
Skiff Builder
Southern NJ Coast
I'm thinking Inside the Box
Double sliding door -mounted inside.
Make no more than 2" thick.
You can place a piece of 1/2" ply over them on the inside so you don't lose your wall space.
Trim on outside part of jamb to weather tighten them up.
whateg01
doo dah, kansas, usa
MT800
Montana
Sorry bout the multiple pics. As you can see the ceiling is pretty low.
Don't have it in me to raise the roof!!!!
BurtEggley
OUT ~ Swinging door out: “the snow will block a swinging door”
IN ~ Swinging door in: "don't really want to sacrifice the floor space to swing a door inward"
BARN ~ "there is not room to run barn doors"
UP ~ "I have a hard height of 84", not enough to raise roll up"
Unless you can somehow engineer a door that uses the 4th dimension, that leaves only a rolling / sliding door, or dig a hole and lower it into the ground 😊 You've ruled out all other dimensions.
Mike65
Horse Pasture, Va.
I will second the sliding barn door. I built one for the barn we had on our property when we lived in upstate NY 16 years ago. I also built one for my basement woodworking shop from tongue & grove pine.
Prospecter
Maine
I settled on swinging doors for my garden shed. Clearing the snow is no big deal, but mostly Ihe don't bother. I usually have the mowers inside, and the snow blower on the tractor before snow flies, and won't need access again until Spring.
JohnX14
Boston 'burbs
I like this idea. Basically a pocket door.
