Shed floor
Johnny Generic
35 miles NE of Pittsburgh, Pa.
Thoughs on not using pt band, joists and floor on a 12 x 16 shed.
Base would be compacted gravel with band resting on concrete blocks. Need to get at least 10 yrs out of it. $$$ savings, reg wood vs pt. Thanks, johnny generic
kd3pc
Northern Neck
I would use pressure treated, rated for ground contact anywhere close to the ground, 0-5". Not the place to save $100.
Even gravel will let moisture pass and wick.
Regular wood that close to the ground is going to fail, quickly and be a PITA to replace once things are set.
ford33
Chicago, IL. USA
Why would you not use PT wood? It is 6 sheets of 4x8 plywood. Cost difference cannot be significant compared to the quality of the material and value of having a proper floor.
SARG
Northeast
I built a 12 x 14 shed over thirty years ago using railroad ties as the perimeter wall base on top of a pad of crusher run. Still doing fine.
